It is currently Tue Aug 12, 2025 7:01 pm
 Post subject: Dovetail router bits
PostPosted: Fri Jan 15, 2016 8:27 pm
City: Lawrence
Zip/Postal Code: 66047
I've decided to tool up and start doing dovetail neck joints instead of M/T.
I have standard bits that are 7degree with a cut length of 1/2".
LMI's are 7 degree with 3/4 " LOC with a 1/2 shank.
the Stew mac's are 10 degree with 13/16 LOC with a 1/4 shank.
I suppose the 1/2 shank might be little more stable than the 1/4.
Do I need a longer LOC than what I have?
Does 10 degree have an advantage over 7 degree?
Thanks for your input.
 Post subject: Re: Dovetail router bits
PostPosted: Fri Jan 15, 2016 8:38 pm
First name: Alex
Last Name: Kleon
City: Whitby
Zip/Postal Code: L1N8X2
Thanks for your input.[/quote]
It's better by 3 degrees. ;) 1/2" shank bits don't chatter as much as a 1/4", but where the dovetail portion of the bit joins at the shank is the weak spot. If you can hog out most of the joint with a straight bit, the dovetail bit will last longer.
I've broken so many D.T. bits for my Leigh jig, I buy them three at a time.
Alex
PostPosted: Fri Jan 15, 2016 9:08 pm
I use 9 degree . I guess a 10 would also work. Seven may be a little light on the angle.
PostPosted: Fri Jan 15, 2016 11:37 pm
First name: David
City: Napa
Zip/Postal Code: 94558
Try MLCS router bits much cheaper btw.
PostPosted: Sat Jan 16, 2016 12:39 pm
First name: ernest
Last Name: kleinman
City: lee's summit
State: mo
Zip/Postal Code: 64081
U might check out the woodcraft in Lenexa KS they have freud and whiteside rtr bits.
Users browsing this forum: Bing [Bot], Gasawdust and 15 guests
